Watch the Video!
This video shows you the making process!
Enjoy! Please leave a Comment and Subscribe!
Design in Adobe Illustrator
Make your design in Illustrator on a 30" X 30" canvas.
Then export a .SVG file.
*Note: You don't need to make this step as I did it for you!
Estimated time: 30 minutes
Open the file in Easel
Import the .SVG file into Easel.
Make sure you enter the correct dimensions of the project which is 30" X 30" X 0.75".
Set the cutting depth at ¾" for the whole design except for the tabs on the seat. (those needs to be set to ½" deep.)
*Note: You don't need to make this step as I also made it for you as well! Just put a 30" X 30" X ¾" material on the machine and carve it!
Estimated time: 1 minutes
Make your Blank
- Take a piece of plywood ¾" thick, and measure a 30" x 30" square. (you can use MDF or laminated wood also)
Estimated time: 5 minutes
Cut your Blank
- Now it's time to cut your blank. I did 31" x 31" on mine just in case but you don't need to. The design is made to fit a 30" x 30" blank.
Install the Blank on the X-Carve
- Install and secure the blank on the X-Carve. I screwed my blank directly on the wasteboard, but if you don't want to damage it, just use clamps provided with the machine.
Carve the Design
The longest part of the process is to wait for the machine to do its job. But it's worth it!
It took me about 2 hours to carve this design with the original parameters. You may be able to save a few minutes by changing the settings.
Estimated time: 120 minutes
Wait for it...
- Stay close to the machine during the process to make sure there are no pitfalls or mechanical breakage. (you're almost there)
Sand your Pieces
- Once the carving is done, remove the pieces from the machine and sand them to avoid splinters.
Assembling
- It's finally time to put the pieces together!
You're done!
- Enjoy your New Knock-Down Stool and don't forget to watch the Video! ;)
