Table Forest
A lovely little forest for your dining room table. Be careful with the smaller trees, they like to pop out and are small enough to be sucked up by the dust collector.
Pieces may be glued or left separate. We chose the latter so we can pack them up flat at the end of the holiday season.
Remakes
x-carve 2016
License
Attribution-NonCommercial 3.0 Unported (CC BY-NC 3.0)Attribution-NonCommercial 3.0 Unported (CC BY-NC 3.0)
You are free:
With the understanding that:
I think you meant 1/4” plywood not 1/2”
Brian Pham · November 05, 2019
Is anyone having problems carving this project? I have attempted twice with same results of large tree lower half not following tool path. Thanks
Greg Ellenberg · November 17, 2019
Where are the two mid size trees?
Mark SigetiPro · October 07, 2020
I carved this. Agree missing the 2 mid sized trees...but still a good design. I had to turn off the vac right before the small trees finished or they'd get sucked up and ruined in the spindle...other than that thanks for the file!!!
Bill Lipp · December 01, 2020
looks like you just reduce the bigger tree to get the mid size going to try now
Christine Simmons · December 12, 2020
Hey y’all! Thank you everyone making these. The mid sized in the sample photo were my prototypes before making this final layout. As already said, you can resize these as you see fit, as long as you adjust the center connection slot approximately.
Adam Simmons · December 12, 2020
Why cannot I modify this? I can with other plans but not this one
Dave · January 02, 2021
I was unable to disassemble a tree using the Exploder application, but I was able to extract the tree outline using the Extract SubPath application.
Sam PickenPro · December 10, 2024
