Getting Started
I have provided the Easel project you can open and use as well as SVG files you can import into your own project. Since there isn't a way to provide multiple Easel projects, I have made the material 3X longer so I could include all shapes in one project.
Open the Easel project and arrange the the shapes you want to cut out. Determine the material thickness you are using and make sure the depth is correct on each opject
Estimated time: 10 minutes
Set up Machine
Put your sheet in your machine and clamp it down. I have used glue, tape and clamps but have found my favorite way to hold down my material is with the "Work piece hold down":https://www.inventables.com/projects/work-piece-hold-down-clamps that Warren posted a bit ago.
Cut Out Shapes
With your material properly held down, select "Carve" and let er rip!!!
Estimated time: 20 minutes
Remove Shapes
Remove the ABS sheet from your machine and cut the tabs to pop out each of the shapes. if necessary sand off burs from where the tabs were.
Stick Em Up
I grabbed some "3M Tape":http://www.amazon.com/3M-109-Wallsaver-Removable-Mounting/dp/B00004Z4BR and just put a piece or two on each shape and pressed them to the wall firmly.
Sit back and relive the glory days of Star Wars!!!
What feeds/speeds did you use?
Mike Machado · September 29, 2015
Simple project perfect done. NICE !!!
Arne FriedrichPro · September 01, 2017
