YoraHome
YoraHome SilverBack Benchtop CNC Router 1X1M
Large-format benchtop CNC with a 100 x 100 cm working area
YoraHome SilverBack Benchtop CNC Router 1X1M machine photo
The SilverBack Benchtop CNC Router 1X1M is YoraHome's large-format benchtop machine, with a 100 x 100 x 10 cm (39 x 39 x 4 in) working area and a 500W spindle motor (52mm diameter mount). YoraHome does not publish stepper motor, drive system, or controller specs for this model.
YoraHome doesn't publish a max RPM for the SilverBack 1X1M's 500W spindle, so check the rating plate on your unit against the chart. Stepper motors and drive system aren't published for this model either, which makes it hard to say how deep a single pass can safely go. Depth per pass is where the machine itself matters: a truly rigid machine with a powerful spindle can cut as deep as the bit is wide in a single pass, but that takes real spindle torque, a drive train and clamps that hold firm, a gantry that will not flex, and enough mass to soak up vibration. Without published rigidity numbers, treat this machine conservatively and take shallower passes. Push too deep and the bit deflects and chatters, leaving scalloped edges, or it rubs instead of cutting and burns the material. The fastest way to dial in a cut is to see what has already worked for other people.
Worked example for feed rate: 1/8in (3.175mm) two-flute solid carbide end mill in hard wood. The chart says 16,000 RPM; YoraHome doesn't publish a max RPM for this spindle, so check the rating plate on your unit and use whatever it allows, up to 16,000. With the bit maker's 0.025mm per tooth (0.0010 in) at 16,000 RPM: 16,000 x 0.025 x 2 = 800 mm/min (31 in/min) feed. Scale that number down if your spindle's actual RPM is lower. For depth per pass, start shallow and check Community Cut Settings in Easel for what works on this machine. If the cut sounds strained, reduce the depth, not the feed. Slowing the feed below the chip load makes the bit rub instead of cut.
500W spindle (52mm mount)
GRBL (Arduino board), version not stated by YoraHome
The SilverBack Benchtop CNC Router 1X1M runs GRBL on an Arduino-based controller (YoraHome does not publish a firmware version), so it connects to Easel as a standard GRBL device. Install the free Easel Driver and plug in over USB, or connect driverless with Rapid Connect in a Chromium browser (Chrome, Edge, or Opera). Design in the browser, then the Carve button homes, zeroes, and runs the job with live progress. You can also export G-code to run from another sender. Select SilverBack Benchtop CNC 1X1M in Easel's machine menu to size the canvas to its 100 x 100 x 10 cm working area.
