The 3018-Pro is YoraHome's entry-level DIY kit CNC, with a 30 x 18 x 4 cm (12 x 7 x 2 in) working area and a 775 spindle motor. It ships as a full kit for self-assembly. YoraHome describes its control board as Arduino-based, but the page does not use the word GRBL for it, and does not state stepper motor or drive system specs.
YoraHome doesn't publish a max RPM for the 3018-Pro's 775 spindle, so check the rating plate on your unit against the chart. Small brushed spindles like a 775 tend to lose torque well before their top rated speed, so if a cut chatters or burns, don't assume more RPM will fix it. Stepper motors and drive system aren't published for this kit either, which makes it hard to say how deep a single pass can safely go. Depth per pass is where the machine itself matters: a truly rigid machine with a powerful spindle can cut as deep as the bit is wide in a single pass, but a light DIY kit like this one falls short of that bar, so take shallower passes. Push too deep and the bit deflects and chatters, leaving scalloped edges, or it rubs instead of cutting and burns the material. The fastest way to dial in a cut is to see what has already worked for other people.
Worked example for feed rate: 1/8in (3.175mm) two-flute solid carbide end mill in hard wood. The chart says 16,000 RPM; YoraHome doesn't publish a max RPM for this spindle, so check the rating plate on your unit and use whatever it allows, up to 16,000. With the bit maker's 0.025mm per tooth (0.0010 in) at 16,000 RPM: 16,000 x 0.025 x 2 = 800 mm/min (31 in/min) feed. Scale that number down if your spindle's actual RPM is lower. For depth per pass, start shallow and check Community Cut Settings in Easel for what works on this machine. If the cut sounds strained, reduce the depth, not the feed. Slowing the feed below the chip load makes the bit rub instead of cut.
The YoraHome CNC Router 3018-Pro runs GRBL on its Arduino Nano (ATMEGA328P) controller, so it connects directly to Easel. Install the free Easel Driver and plug in over USB, or connect driverless with Rapid Connect in a Chromium browser (Chrome, Edge, or Opera). Design in the browser, then the Carve button homes, zeroes, and runs the job with live progress. You can also export G-code to run from another sender. Select Yora CNC Carving Machine 3018-Pro in Easel's machine menu to size the canvas to its 30 x 18 x 4 cm working area.
