Sienci Labs
Sienci Labs LongMill MK3
Current benchtop CNC in two working-area sizes, lead screw driven with linear guide rails
Sienci Labs LongMill MK3 machine photo
The LongMill MK3 is Sienci Labs' current benchtop CNC, sold in two working-area sizes: 30x30 at 32in x 32in, and 48x30 at 49in x 32in, both with 5.1in of Z-axis travel and 4.6in of clearance. It runs high-torque, closed-loop NEMA 23 steppers (1.2 Nm) on T12 lead screws with 15mm profiled linear guide rails on all axes, and it ships with a standard 65mm router mount only; router or spindle is not included. It is controlled by Sienci's SLB-LITE controller, which the manufacturer states runs grblHAL firmware.
The LongMill MK3 does not come with a bundled spindle, so its top RPM depends on what you mount to the 65mm holder (it also supports 80mm spindles with a larger dust shoe, though that reduces cutting area). Sienci's recommended options, its own AutoSpin T1 or a Makita RT0701, both reach at least 30,000 RPM, comfortably above every speed on the chart, so with either of those you can run the chart's recommended RPM directly. This is a lead-screw kit on high-torque, closed-loop NEMA 23 steppers with 15mm profiled linear guide rails and anti-backlash nuts, sturdier than a small belt-driven hobby machine but still a benchtop kit, not a heavy industrial mill. A truly rigid machine with a powerful spindle can cut as deep as the bit is wide in a single pass, but that takes real spindle torque, a drive train and clamps that hold firm, a gantry that will not flex, and enough mass to soak up vibration. The MK3's build gets partway there, so take moderate passes and build up rather than assuming full-diameter depth from the start. Push too deep and the bit deflects and chatters, leaving scalloped edges, or it rubs instead of cutting and burns the material. The fastest way to dial in a cut is to see what has already worked for other people.
Worked example for feed rate: 1/8in (3.175mm) two-flute solid carbide end mill in hard wood. The chart says 16,000 RPM. With Sienci's recommended AutoSpin T1 or a Makita RT0701 mounted, both cover that easily, so run 16,000; check whatever spindle you actually mount if it is different. With the bit maker's 0.025mm per tooth (0.0010 in): 16,000 x 0.025 x 2 = 800 mm/min (31 in/min) feed. For depth per pass, start shallow and check Community Cut Settings in Easel for what works on this machine. If the cut sounds strained, reduce the depth, not the feed. Slowing the feed below the chip load makes the bit rub instead of cut.
30x30: 32 x 32 in, 5.1 in Z travel, 4.6 in Z clearance; 48x30: 49 x 32 in, 5.1 in Z travel, 4.6 in Z clearance
65mm router mount (also compatible with an 80mm spindle plus dust shoe, which reduces cutting area); router or spindle not included
NEMA 23 closed-loop, 1.2 Nm on all axes
T12 lead screws on all axes, 15mm profiled linear guide rails and bearing blocks, anti-backlash nuts, y-axis auto-squaring
SLB-LITE (grblHAL firmware)
USB-C (setup/firmware flashing) or Ethernet
The LongMill MK3 runs grblHAL firmware on Sienci's SLB-LITE controller. Easel's live control, the Easel Driver and Rapid Connect, works with classic GRBL and FluidNC over USB, so it does not carve this machine in real time. Use Easel to design and generate toolpaths, then export the G-code and run it from the machine's own controller through gSender over USB or Ethernet. Because Easel's G-code is standard GRBL, it runs as-is. Select the LongMill MK3, choosing the 30x30 or 48x30 size, in Easel's machine menu to size the canvas.
