SainSmart Genmitsu PROVerXL 2x2
Large-format CNC with a 710W spindle and closed-loop steppers
SainSmart Genmitsu PROVerXL 2x2 machine photo
The Genmitsu PROVerXL 2x2 has a 679 x 679 x 113 mm working area, a 710W spindle (30,000 RPM, water-cooled spindle optional), and four closed-loop NEMA23 stepper motors (3.5 Nm torque) on linear guides with ball screws.
The PROVerXL 2x2's 710W spindle runs up to 30,000 RPM, which covers the entire chart, so dial it to whatever the chart recommends for the material and bit rather than leaving it pinned at max. Depth per pass is where the machine itself matters. A truly rigid machine with a powerful spindle can cut as deep as the bit is wide in a single pass, and that takes real spindle torque, a drive train and clamps that hold firm, a gantry that will not flex, and enough mass to soak up vibration. Four closed-loop NEMA23 steppers on HG15/HG20 linear guides with ball screws put this machine closer to that standard than any other SainSmart desktop kit, so you can push deeper passes, but still watch and listen for chatter before assuming full bit-width depth. Push too deep and the bit deflects and chatters, leaving scalloped edges, or it rubs instead of cutting and burns the material. The fastest way to dial in a cut is to see what has already worked for other people.
Worked example for feed rate: 1/8in (3.175mm) two-flute solid carbide end mill in hard wood. The chart says 16,000 RPM, and this spindle's adjustable range covers that, so dial it to 16,000. With the bit maker's 0.025mm per tooth (0.0010 in): 16,000 x 0.025 x 2 = 800 mm/min (31 in/min) feed. For depth per pass, start shallow and check Community Cut Settings in Easel for what works on this machine. If the cut sounds strained, reduce the depth, not the feed. Slowing the feed below the chip load makes the bit rub instead of cut.
679 x 679 x 113 mm (2.23 x 2.23 x 0.37 ft)
710W AC spindle, 30,000 RPM (1.5-2.2kW water-cooled optional)
Four NEMA23 closed-loop, 3.5 Nm
Linear guides (HG20 Y, HG15 X/Z) with ball screws (20mm X/Y, 12mm Z)
GRBL 1.1h (32-bit board)
USB serial (CH341SER driver) or WiFi
The Genmitsu PROVerXL 2x2 runs GRBL 1.1h on its 32-bit board, so it connects directly to Easel. Install the free Easel Driver and plug in over USB, or connect driverless with Rapid Connect in a Chromium browser (Chrome, Edge, or Opera). Design in the browser, then the Carve button homes, zeroes, and runs the job with live progress. You can also export G-code to run from another sender. Select Genmitsu PROVerXL 2x2 in Easel's machine menu to size the canvas to its 679 x 679 x 113 mm working area.
