Sainsmart
Sainsmart Cubiko CNC Router
Entry-level desktop CNC with a 75W spindle, ready to use out of the box
Sainsmart Cubiko CNC Router machine photo
The Cubiko CNC Router has a 150 x 110 x 40 mm working area (58 mm Z gantry clearance), a 75W spindle (10,000 RPM max), and NEMA 17 stepper motors on an 8mm lead screw drive.
The Cubiko's spindle tops out at 10,000 RPM, below most of the chart. It's a small 75W spindle that loses torque near the top of its range, so leave it near 10,000 for everything and control the cut with feed rate instead. If acrylic starts to melt, speed the feed up rather than slowing the spindle, and skip aluminum on this spindle except for light engraving. Depth per pass is where the machine itself matters. A truly rigid machine with a powerful spindle can cut as deep as the bit is wide in a single pass, but that takes real spindle torque, a drive train and clamps that hold firm, a gantry that will not flex, and enough mass to soak up vibration. This is a small desktop machine on a lead screw drive, well short of that bar, so take shallower passes. Push too deep and the bit deflects and chatters, leaving scalloped edges, or it rubs instead of cutting and burns the material. The fastest way to dial in a cut is to see what has already worked for other people.
150 x 110 x 40 mm (5.91 x 4.33 x 1.57 in)
NEMA 17
Lead screw, 8mm diameter
GRBL-compatible (own-branded Cubiko Firmware; no GRBL version stated)
USB serial (CH341 chip); also standalone via SD card or WiFi
The Cubiko runs GRBL-compatible firmware (Sainsmart's own-branded Cubiko firmware, with no GRBL version stated), so it connects to Easel as a standard GRBL device over USB. Install the free Easel Driver and plug in over USB serial (CH341 chip), or connect driverless with Rapid Connect in a Chromium browser (Chrome, Edge, or Opera). Design in the browser, then the Carve button homes, zeroes, and runs the job with live progress. You can also export G-code to run standalone from the machine's SD card or WiFi connection. Select Cubiko in Easel's machine menu to size the canvas to its 150 x 110 x 40 mm working area.
