Meissa CNC
Meissa CNC Meissa 3
DIY 3D-printed CNC router build with a 20.5 x 14 x 2.5in working area
Meissa CNC Meissa 3 machine photo
20.5 x 14 x 2.5 in (X x Y x Z)
Takes a compact router mounted in a 65mm or 70mm tool holder; router not included. Supply your own router, check its RPM plate, and control the cut by feed rate to match its actual top speed.
4 NEMA17 stepper motors
Belt drive (moved by 4 NEMA17 stepper motors)
GRBL (Arduino Uno); works with Meissa's own PilotCNC sender, plus Easel, UGS, and Candle
The Meissa 3 runs GRBL firmware on its Arduino Uno board, so it connects to Easel as a standard GRBL device over USB. Install the free Easel Driver and plug in over USB, or connect driverless with Rapid Connect in a Chromium browser (Chrome, Edge, or Opera). Design in the browser, then the Carve button homes, zeroes, and runs the job with live progress. You can also export G-code to run from another sender, including Meissa's own PilotCNC (a GRBL-compatible sender). Select Meissa 3 in Easel's machine menu to size the canvas.
