Inventables
Inventables X-Carve (2021 Upgrade)
Belt-driven CNC kit with a Makita router, 3x faster and more rigid than the original X-Carve
Inventables X-Carve (2021 Upgrade) CNC machine
Inventables no longer sells this model, but it remains fully supported in Easel. This later X-Carve generation has a 29.5in x 29.5in working area with 4.5in of Z travel, drives X and Y on belts with Delrin V-wheels and Z on a precision-guided acme leadscrew, and ships with a 1.25 HP (800W) Makita router rated 10,000 to 30,000 RPM. Inventables states it is 3x faster, more rigid, and more accurate than the original X-Carve.
This X-Carve's Makita router runs from 10,000 to 30,000 RPM, comfortably above every speed on the chart, so you can run the chart's recommended RPM directly instead of capping it. It is a belt-driven kit on Delrin V-wheels with a precision-guided acme leadscrew Z-axis, a step up in rigidity from the original X-Carve but still a hobby-grade machine, not a heavy industrial mill. A truly rigid machine with a powerful spindle can cut as deep as the bit is wide in a single pass, but that takes real spindle torque, a drive train and clamps that hold firm, a gantry that will not flex, and enough mass to soak up vibration. This machine gets partway there, so take moderate passes and build up rather than assuming full-diameter depth from the start. Push too deep and the bit deflects and chatters, leaving scalloped edges, or it rubs instead of cutting and burns the material. The fastest way to dial in a cut is to see what has already worked for other people.
Worked example for feed rate: 1/8in (3.175mm) two-flute solid carbide end mill in hard wood. The chart says 16,000 RPM, and this router's 10,000 to 30,000 RPM range covers that easily, so run 16,000. With the bit maker's 0.025mm per tooth (0.0010 in): 16,000 x 0.025 x 2 = 800 mm/min (31 in/min) feed. For depth per pass, start shallow and check Community Cut Settings in Easel for what works on this machine. If the cut sounds strained, reduce the depth, not the feed. Slowing the feed below the chip load makes the bit rub instead of cut.
29.5 x 29.5 x 4.5 in
Makita router, 1.25 HP (800W)
NEMA-23 stepper motors (bi-polar, 4-wire, 1/4 in (6.35 mm) shaft), three total: two on Y and one on X. The X-Carve Upgrade motors are 65 mm long versus 51 mm on the standard motors (part KL23H265-28-4AP-1, with pulleys pre-installed).
Belt drive with Delrin V-wheels on X and Y; precision linear bearings with acme leadscrew on Z
Inventables X-Controller, a GRBL controller with adjustable stepper drivers tuned to roughly 2.6 to 2.8 A, 8x microstepping on X and Y and 2x on Z, an enclosed power supply, and a USB connection to the computer.
The X-Carve (2021 Upgrade) runs GRBL through its Inventables X-Controller, so it connects directly to Easel. Install the free Easel Driver and plug the X-Controller in over USB, or connect driverless with Rapid Connect in a Chromium browser (Chrome, Edge, or Opera). Design in the browser, then the Carve button homes, zeroes, and runs the job with live progress. You can also export G-code to run from another sender if you prefer. Select 'X-Carve (November 2021 Upgrade)' in Easel's machine menu to size the canvas to its 29.5in x 29.5in working area.
