Rack-and-pinion CNC kit with non-GRBL electronics packages, five kit sizes
The Upshot Mill ships without a spindle, so its top RPM depends on whatever unit you mount, up to 2.2kW, check that unit's own rating plate against the chart rather than assuming a number. Its rack-and-pinion X/Y drive, HD ballscrew-driven Z axis with 8in of travel, and 15mm square linear bearings on every axis are built for real rigidity. A truly rigid machine with a powerful spindle can cut as deep as the bit is wide in a single pass, but that takes real spindle torque, a drive train and clamps that hold firm, a gantry that will not flex, and enough mass to soak up vibration. With a suitable spindle mounted, the Upshot Mill can handle solid depth per pass, but still build up gradually. Push too deep and the bit deflects and chatters, leaving scalloped edges, or it rubs instead of cutting and burns the material. The fastest way to dial in a cut is to see what has already worked for other people.
Worked example for feed rate: 1/8in (3.175mm) two-flute solid carbide end mill in hard wood. The chart says 16,000 RPM. This machine ships without a spindle, so check the RPM rating on whatever you mount, up to 2.2kW, and use its actual number if it differs from 16,000. With the bit maker's 0.025mm per tooth (0.0010 in), at 16,000 RPM: 16,000 x 0.025 x 2 = 800 mm/min (31 in/min) feed. For depth per pass, start shallow and check Community Cut Settings in Easel for what works on this machine. If the cut sounds strained, reduce the depth, not the feed. Slowing the feed below the chip load makes the bit rub instead of cut.
The Upshot Mill's electronics packages run either a C4N Controller with UC100/UCcnc software or a Masso G3 Touch, and neither is GRBL or FluidNC, so Easel's live Driver and Rapid Connect do not drive this machine directly. Instead, set up a Non-GRBL Machine Profile for the Upshot Mill in Easel, design your project as usual, then use Project > Download G-code to save an .nc file. If you have the UC100/UCcnc package, open that .nc file in the UCCNC software on the PC wired to the mill and run it from there. If you have the Masso G3 Touch package, transfer the .nc file to the controller over its built-in WiFi via Masso Link, or by USB drive, and run it from the touchscreen. Either way, Easel handles design and toolpath generation, and the controller's own software runs the job.
