Rack-and-pinion CNC kit with a standard HD ballscrew Z axis, four kit sizes under one Easel entry
The PRO48xxRP covers four kit sizes sold on one product page: 4824 at 50 x 25 x 8 in, 4836 at 50 x 37 x 8 in, 4848 at 50 x 49 x 8 in, and 4896 at 50 x 99 x 8 in (footprint 62.5 x 34.5 in up to 62.5 x 106.5 in depending on size, using a 3/4in MDF wasteboard). It runs rack-and-pinion drive with a belt reduction box on X/Y, 15mm square linear bearings on every axis, and now ships standard with an HD 6in-wide ballscrew Z axis that can take a spindle up to 3kW, not included; mount options run from 65mm up to 89mm.
The PRO48xxRP ships without a spindle, so its top RPM depends on whatever unit you mount, up to 3kW, check that unit's own rating plate against the chart rather than assuming a number. Its rack-and-pinion X/Y drive and 15mm square linear bearings on every axis, plus a standard HD 6in-wide ballscrew Z axis, are built for real rigidity. A truly rigid machine with a powerful spindle can cut as deep as the bit is wide in a single pass, but that takes real spindle torque, a drive train and clamps that hold firm, a gantry that will not flex, and enough mass to soak up vibration. With a suitable spindle mounted, the PRO48xxRP can handle solid depth per pass, but still build up gradually. Push too deep and the bit deflects and chatters, leaving scalloped edges, or it rubs instead of cutting and burns the material. The fastest way to dial in a cut is to see what has already worked for other people.
Worked example for feed rate: 1/8in (3.175mm) two-flute solid carbide end mill in hard wood. The chart says 16,000 RPM. This machine ships without a spindle, so check the RPM rating on whatever you mount, up to 3kW, and use its actual number if it differs from 16,000. With the bit maker's 0.025mm per tooth (0.0010 in), at 16,000 RPM: 16,000 x 0.025 x 2 = 800 mm/min (31 in/min) feed. For depth per pass, start shallow and check Community Cut Settings in Easel for what works on this machine. If the cut sounds strained, reduce the depth, not the feed. Slowing the feed below the chip load makes the bit rub instead of cut.
The PRO48xxRP ships with one of three non-GRBL electronics packages depending on configuration: a Gecko540/UC100 stack or a UC400ETH setup running UCCNC (Mach3-style PC control software), or a Masso G3 Touch standalone controller for other builds. Since none of these is GRBL or FluidNC, Easel's live Driver connection and driverless Rapid Connect do not apply here; instead, set up a Non-GRBL Machine Profile in Easel, design your project, then use Project > Download G-code to save an .nc file. If your machine runs UCCNC (the Gecko540/UC100 or UC400ETH setups), open that exported .nc file directly in UCCNC on the PC wired to the machine and run the job from there. If your machine runs a Masso G3 Touch, transfer the .nc file to the controller over its built-in WiFi via Masso Link, or by USB drive, and run it from the touchscreen.
