CNC4Newbie
CNC4Newbie C4NminiTK
Compact turnkey CNC kit with UCcnc control and an optional GRBL add-on
CNC4Newbie C4Nmini Turnkey CNC Machine
11.125 x 12 x 7 in (+/-)
4x stepper motors, 178 oz-in
8mm diameter leadscrew (8mm/turn) on X/Y/Z; square linear bearings on all axes; adjustable anti-backlash system; same Z axis as the New-Carve; 2040 aluminum extrusion base frame; X axis from 1x3in aluminum extrusion
UCcnc/GeckoDrive G540 (default, not GRBL); optional third-party GRBL Demon Controller
The C4NminiTK's stock control stack is UCcnc software paired with a GeckoDrive G540 breakout board, not GRBL or FluidNC, so Easel's live Driver and Rapid Connect do not connect to it directly. To carve on this setup, set up a Non-GRBL Machine Profile in Easel, design your project as usual, then use Project > Download G-code to save the toolpath as an .nc file. Transfer that file to the PC running UCcnc (by USB drive or network share) and open it in the UCcnc software, which is wired to the G540 board and drives the machine. If your C4NminiTK has instead been upgraded with the optional third-party GRBL-based Demon Controller, it runs GRBL, so it connects live through the Easel Driver instead of using the export workflow.
