CNC4Newbie
CNC4Newbie C4N4836TK
Turnkey CNC kit with UCcnc/GeckoDrive control, 50 x 38 in work area
CNC4Newbie C4N4836TK machine photo
The C4N4836TK ships without a spindle, so its top RPM depends on whatever router or spindle you mount, check that unit's own rating plate against the chart rather than assuming a number. Its 12mm leadscrew drive on all three axes with square linear bearings and an adjustable anti-backlash system is solid for a hobby-to-prosumer kit, but a leadscrew frame is still lighter duty than a ball-screw or rack-and-pinion machine. A truly rigid machine with a powerful spindle can cut as deep as the bit is wide in a single pass, but that takes real spindle torque, a drive train and clamps that hold firm, a gantry that will not flex, and enough mass to soak up vibration. The C4N4836TK falls short of that bar, so take shallower passes. Push too deep and the bit deflects and chatters, leaving scalloped edges, or it rubs instead of cutting and burns the material. The fastest way to dial in a cut is to see what has already worked for other people.
Worked example for feed rate: 1/8in (3.175mm) two-flute solid carbide end mill in hard wood. The chart says 16,000 RPM. This machine ships without a spindle, so check the RPM rating on whatever you mount and use its actual number if it differs from 16,000. With the bit maker's 0.025mm per tooth (0.0010 in), at 16,000 RPM: 16,000 x 0.025 x 2 = 800 mm/min (31 in/min) feed. For depth per pass, start shallow and check Community Cut Settings in Easel for what works on this machine. If the cut sounds strained, reduce the depth, not the feed. Slowing the feed below the chip load makes the bit rub instead of cut.
50 x 38 x 6 in
4x 269 oz-in stepper motors (included in the controller package)
12mm diameter leadscrew (12mm/turn) on X/Y/Z; 4-race square linear bearings on all axes; fully adjustable brass anti-backlash system; 1x3in aluminum extrusion base frame; C-beam-style X axis from 2x4in aluminum extrusion
UCcnc/GeckoDrive G540 (not GRBL)
The C4N4836TK runs a GeckoDrive G540 driven by UCCNC, not GRBL or FluidNC, so Easel's live Driver and driverless Rapid Connect do not connect to this machine directly. Instead, set up a Non-GRBL Machine Profile in Easel, design your project as usual, then use Project > Download G-code to save the toolpath as an .nc file. Transfer that file to the PC wired to the machine's G540 controller, then open and run it directly in the UCCNC software.
