Ben Uyeda Outdoor Lounge 1x6 V2by Ben UyedaOutdoor Lounge Chair
A full-size lounge chair made from 1 × 5½-inch deck boards. The shared files shape the side frames; plan the slat length, board count, joinery, and outdoor finish before cutting.
For the campsite, patio, or next trip
Build a lounge chair for the deck, a camper sign, or a piece for your next trip. Adapt the size, material, and finish to where the project will live.
Start with the destination
Outdoor projects have to solve more than a visual problem. A chair carries weight, a campsite sign needs to read from a distance, and anything left outside has to handle moisture, sun, movement, and repeated use.
Begin with the place and purpose, then choose the project. That keeps the design focused and makes the material, joinery, bit, and finish decisions easier to test before the final cut.
Real projects from the Easel gallery
Each published project has a working preview and copy path. Open one to inspect the design and toolpaths, then adapt the dimensions, stock, lettering, and finish. The signs use V-carving, which requires Easel Pro; you can start with a free trial.
Ben Uyeda Outdoor Lounge 1x6 V2by Ben UyedaA full-size lounge chair made from 1 × 5½-inch deck boards. The shared files shape the side frames; plan the slat length, board count, joinery, and outdoor finish before cutting.
Adventure Signby Sam AlaimoA carved MDF sign with bold outdoor lettering and a shaped profile. The maker used a V-bit, sanding sealer, black paint, and surface sanding to keep the fine details crisp.
Camper signby James StewartA layered birch-plywood camper sign with an editable name. The design uses a 90-degree V-bit for the face and a ⅛-inch bit for the cutout, then adds paint for contrast.
Before you cut
A campsite sign has to stay readable from the road, while furniture has to fit both a person and the space around it. Confirm the final dimensions before changing artwork or generating toolpaths.
Deck boards suit an outdoor chair better than indoor MDF, while flat plywood can simplify a layered sign. Measure the actual thickness and width of every board; nominal lumber sizes are not finished dimensions.
Seal exposed edges and carved pockets, use exterior-rated glue and hardware where the build needs them, and choose a finish that matches the wood and exposure. No finish makes an indoor material permanently weatherproof.
Cut a joint, small lettering sample, or layered detail before committing the full project. Check the bit, fit, paint bleed, sanding sequence, and finish on offcuts from the same stock.
Start with a real community project, adapt it for your campsite, patio, or next trip, and prepare the design for your CNC with a free Easel Pro trial.
Start a free Pro trial →
