Halloween Lampby Jeff ParishHalloween Lamp
A glowing box lantern built from carved panels, with assembly and finishing instructions plus a community remake to learn from.
Spooky projects, proven designs
Start with a real community project for the porch, yard, or party table. Copy the design into Easel, change the details, and make a decoration that fits your material and machine. Creating an Easel account is free. No credit card required.
Make the season your own
Halloween decorations are a good fit for CNC because a simple silhouette can become a sign, a lantern panel, or a whole yard display. Starting from a finished project also gives you real guidance on bits, materials, assembly, and paint so you use your creativity to build on the work of other makers.
Choose the build that fits your available stock and time. Then copy it into Easel to change the size, swap the words, simplify small details, or combine parts from the design with your own artwork.
Real projects from the Easel gallery
Each project has a design file, pictures and it's ready for you to add your own customizations. Open one that inspires you to carve it as is or adjust the design for your own porch or yard.
Halloween Lampby Jeff ParishA glowing box lantern built from carved panels, with assembly and finishing instructions plus a community remake to learn from.
Halloween Tombstonesby Ty MoserA front-yard set with five designs and detailed notes for cutting, painting, weathering, and staking foam tombstones outdoors.
Monogram Pumpkinby RustyA painted pumpkin sign with bit guidance, tab advice, and a step-by-step finish that is easy to personalize with your own words.
Before you cut
The featured builds use MDF, foam board, and sheet goods in different ways. Set the real stock thickness in Easel, choose cut settings for that material, and make a small test cut before starting the full piece.
Thin pumpkin stems, letters, and decorative edges can move near the end of a profile cut. Add enough tabs to hold the part securely, and make them thicker than the minimum when the project has narrow details.
The lamp design looks best when it glows, but an LED light avoids the heat and open flame of a candle around painted panels and plastic inserts. Keep wiring and the light source clear of cut edges.
Seal faces and exposed edges before outdoor use, especially on MDF or plywood. For foam tombstones, follow the project’s paint notes because solvent-based spray paint can attack the material.
Create a free Easel account, no credit card required. Copy a community design, change the details, and make a decoration for your porch, yard, or table.
