Make a wooden step stool for your home
Build a small step for the kitchen or bathroom. Explore real wooden stools, then open a shared Easel design for the parts or carving you want to make.
Explore the stools
Design a step stool side panel in Easel
Watch a birch plywood side-panel design take shape in Easel. Add an arched outline between the feet, a rounded handle shape and a rectangular tread slot, then turn the 3D preview to view the cut paths.
Recorded in the Easel editor, playing at 8× real speed.
Fitted plywood steps, carved tops and a carry handle
Choose the shape and construction you want. Each project explains which parts come in the shared design and which you make separately.
See more stepstool search results →
From the makers’ comments and project notes
Details to use in your own step stools build
Keep the stool’s mating edges square
Robert Rieke rounds the exposed edges after a successful dry fit, but leaves the ends of the curved supports and the bottom of the carry handle square where they meet a glue joint. Ease the edges you will touch, not the surfaces that need to fit together.
Project notes by Robert Rieke: read the source.
From MWP X-Carve Stepstool by Robert Rieke.
Start with the stool you want to make
Open a shared design, then make a free Easel account to save your own copy.
