Slide-Under Sofa Tableby Ryan CurrierSlide-Under Sofa Table
Bring a tray surface over the sofa cushion with a base that slides underneath. Ryan’s plywood design has three round recesses and a larger rectangular tray area. The shared workpiece contains the top, two side frames and connecting pieces. Match the joints to your actual plywood thickness, and check the base clearance and tabletop height against your sofa.
