611 Dust Shoeby Stuart Campbell611 Dust Shoe
Stuart’s 611 shoe separates into magnet-held halves for bit access. His workpiece supplies the shoe, ring and bracket shapes; his instructions use nominal 10 mm PVC, measured at 10.3 mm, and also allow plywood or MDF. Set Easel’s stock thickness to your measured sheet. Add magnets, a PVC hose riser, epoxy and temporary superglue for the fitted ring/bracket assembly, plus a router-mount screw and separate No. 6 skirt screws. Fit and bond the riser, ring and adjustable bracket on the machine, then screw the vinyl skirt around the edge. His final skirt was about 2 inches tall; measure your own machine before trimming it.
