Minimal EDC Wood & Leather Walletby WoodbrewMinimal EDC Wood & Leather Wallet
Woodbrew’s native walnut outline is approximately 100 × 61 mm, with a card recess approximately 86 × 54 mm. Check those recess dimensions against the cards and stack thickness you intend to carry. Four workpieces hold the body operations and separate insert layout. Assembly uses separate 3/4-inch elastic and adhesive: superglue the elastic around the wooden body, then CA-glue the decorative insert over the elastic. The maker uses acrylic, leather or aluminum for that insert. The wooden body is carved on two sides.
