Wooden stands and docks
Make your own phone stand
Keep your phone upright for a video call, prop it beside your tools, or make a small stand to take with you. Explore real builds you can adapt in Easel. Creating an account is free. No credit card required.
Explore the phone stands
Design your own phone stand
Lay out the back and base in Easel, add the matching slots and cable-hole outline, then preview the two-piece design in 3D.
Recorded in the Easel editor, playing at 8× real speed.
From the Easel gallery
Slot plywood together, add a charger, or carve a sound cavity
Choose a stand for the way you use your phone. Each project links to the maker’s build and its Easel design, with extra parts and fitting steps noted below.
See more phone stand search results →
From the makers’ comments and project notes
Details to use in your own phone stand build
Seal the carved edges before adding the dark paint
Douglas Briney applied two coats of semigloss spray polyurethane and let them dry before spraying two coats of black paint. He then sanded the surface to leave the dark carving visible. Sealing the edges first helped keep the paint from bleeding beyond the design.
Comment by Douglas Briney: read the source.
From Cellphone stand by Douglas Briney.
Make a stand that fits your phone
Create a free Easel account, no credit card required. Start with a maker’s design, then adapt the fit and finish for your phone.
