Make a peg-solitaire board
Lay out a 33-hole peg-solitaire board in Easel and size the blind holes for the pins you want to play with.
See the finished builds
Design your own peg-solitaire board
The animation below shows drawing a peg-solitaire board from scratch in Easel. Blind holes in the hardwood board seat the stems of separate metal shelf-support pins while their wider heads remain above the surface. Start with 32 pins and the center empty; jump a pin over its neighbor into an empty seat, then remove the jumped pin. For this untested design, assume 5 mm stems and heads no wider than 8 mm. Draw a 110 × 110 mm outside profile in 12.7 mm hardwood. Add 5.2 mm circles, 6 mm deep, on 12 mm centers in seven rows of 3, 3, 7, 7, 7, 3 and 3 seats. Keep the cross centered. Each seat leaves 6.7 mm of wood below it, with 0.2 mm total stem clearance and 4 mm between the reference pin heads. Remove the outside-cut holding tabs, smooth the board and fit-test the selected pins on scrap before assembly.
Recorded in the Easel editor, playing at 4× real speed.
Shelf-support pins or cribbage pegs
The pin stem determines the seat diameter, and its head determines the space between moves. Choose shelf-support pins or cribbage pegs, then size the playing pattern around that set.
See more solitaire search results →
Start with 5 mm shelf pins and an empty center
Log in to post a question in the project discussion; replies are not guaranteed.
Mitch Peacock’s peg instructions call for 5 mm chromed shelf-support pins and a few spares. His setup step fills the game holes while leaving the central hole empty.
Project notes by Mitch Peacock: read the source.
From English Solitaire by Mitch Peacock.
