Make a small desk for the couch or bed
Make room for breakfast, a laptop or a notebook. Explore community-built lap desks and bed tables, then open a shared Easel design to make one like it.
Explore the lap desks
Design your own lap desk
Lay out a lap desk top in Easel with vent slots, a cup holder, a phone slot and a carry handle, then check the design in 3D.
Recorded in the Easel editor, playing at 8× real speed.
A flat place to work or eat away from the desk
Compare complete plywood designs and a slotted top you can add to your own build. Each project explains what the shared file supplies.
A pale plywood bed tray with handles along its raised side supports and a circular recess in the top Bed Tray with Carrying Handlesby BCNC Custom by Jeanik & Alejandro
Carry breakfast to bed on a tray with raised handles and a round recess in the top. Jeanik and Alejandro’s design slots together from plywood and comes apart for storage. Their instructions specify 10 mm plywood and a one-eighth-inch straight bit. The shared workpiece includes the tabletop and interlocking sides. Use the actual sheet thickness when fitting the joints.
An open laptop and a phone on a pale wooden table resting on a bed Bent-Wood Table with a Phone Holderby David Márquez Kacic
Give a laptop and phone their own places on a wide bent-wood table. David’s photographed version uses pine and Chilean raulí, while the shared design uses maple and walnut presets. Three workpieces provide the underside relief and charger recess, tabletop outline and separate phone supports. Follow the maker’s two-sided carving and bending sequence, and supply a compatible charging module separately.
See more lap-desk search results →
From the makers’ comments and project notes
Details to use in your own lap desks build
Cut matching leg curves together
Ben Ezzell clamped his lap-desk legs together before cutting their curve on a band saw, then smoothed them on an oscillating spindle sander. The Easel file supplies the ventilation pattern, while this separate shop step makes a matching pair of supports for the desk.
Comment by Ben Ezzell: read the source.
From Lap Desk by Ben Ezzell.
