Make a stand for your headphones
Shape a rounded headband support and fit it into a broad base in Easel.
See the headphone stands
Round the support and fit its tenon into the base
Make a wooden headphone stand with a rounded support and a separate base, using Steve Carmichael’s walnut build as the assembly reference. Wood glue joins the parts; self-stick felt cushions the headband, with no metal hardware.
Recorded in the Easel editor, playing at 1× real speed.
First draw a 2-inch-wide upright and overlap a 2-inch circle at its top. Add a centered tenon, then Combine the three shapes into one outline: the shoulder-to-crown height is 8 inches and the tenon projects another ½ inch below it.
Next draw a 6 × 5-inch base and place a ¾-inch-square mortise at its center, ½ inch deep in the example’s ¾-inch stock. Use outside cuts for the upright and base, and a pocket for the mortise.
After carving, round the tenon corners to match the router-cut mortise, dry-fit the joint, glue and clamp it square, then add felt over the crown.
Measure your actual stock and headphones before adapting the dimensions: the socket must match the wood’s thickness and the earcups need clearance above the base. The recording shows the flat cutting layout and native preview, not a physical build or stability test.
Keep audio adapters nearby or paint a gaming emblem
The walnut music-note stand includes places for a cable and plug adapters. The painted MDF holder trades that storage for an Overwatch emblem around the headband support.
See more headphone-related gallery projects →
From the makers’ instructions
Fit the mortise corners and plan the paint sequence
The project discussions are public to read. Log in to add a comment.
Round the tenon, not the mortise
Steve Carmichael explains that a round router bit leaves rounded corners inside the base’s mortise. In his sanding step, he sands the tenon’s corners for the best fit. His top-carving instructions also say to resize the mortise if the lumber thickness changes.
Project notes by Steve Carmichael: read the source.
From Headphone Stand by Steve Carmichael.
Keep glue squeeze-out away from the paint
Kenny hammerlund says to glue and clamp the two pieces, warns about squeeze-out, and suggests assembling before painting. His finishing step lists spray paint and a lacquer clear coat.
Project notes by Kenny hammerlund: read the source.
From Overwatch Headphone holder by Kenny hammerlund.
Leave room below the earcups
Size the upright around the headphones you use, then keep the headband above a broad base. A cord opening and adapter pockets can keep the audio accessories with the stand.
