Garden Markers 1by Charlie - River's EdgeVegetable-name stakes
Green-and-white HDPE markers pair vegetable names with small drawings. The shared project has two label sets and a separate reverse-side joke workpiece.
Mark vegetable rows with names or colorful characters, or add illustrated herb tags to a planter. Explore shared designs or customize your own.
Creating an Easel account is free. No credit card required.
On an empty workpiece, draw a closed pointed outline with Easel’s vector tool. Turn the marker so its tip points right, then add BASIL with the text tool and place the upright lettering inside the stake. This staged screenshot animation shows the native drawing steps and the resulting 3D preview.
This unsaved design demonstration does not show a finished carve. Set the stock thickness, outline depth and workholding for the material you use before cutting.
These builds put labels in different places: directly in the soil, on clear stakes or against the front of a planter. Each has a shared Easel design and a credited maker.
Garden Markers 1by Charlie - River's EdgeGreen-and-white HDPE markers pair vegetable names with small drawings. The shared project has two label sets and a separate reverse-side joke workpiece.
Acrylic Garden Makersby Sarah MilneColored acrylic vegetables mark garden rows with recognizable shapes. Separate color workpieces supply the bodies and leafy pieces, with a sixth workpiece for clear stakes. Glue the colored pieces together after carving; Sarah also describes using wooden stakes.
Herbs Labelsby Cristiana FelgueirasSmall Corian tags label the front of a planter box instead of standing in the soil. Cristiana Felgueiras shares a sheet of illustrated labels with Portuguese herb names. Use the file for the tags and choose fasteners for your own planter.
See more garden marker search results →
From maker notes and the project discussion
The project pages show these maker notes and comments. To add your own question in the discussion, log in to Easel.
Charlie used double-faced tape to hold his two-color HDPE and a 1/16-inch O-flute bit for these narrow markers. His notes specify no tabs. That is a workholding choice for this plastic sheet, not a reason to remove tabs from every material.
Project notes by Charlie - River's Edge: read the source.
From Garden Markers 1 by Charlie - River's Edge.
Ask a questionThe herb sheet uses Portuguese names. In the project discussion, Cristiana explains that you can change the words to your own language. Replace the text with the herbs you grow while keeping the illustrated tag shapes.
Comment by Cristiana Felgueiras: read the source.
From Herbs Labels by Cristiana Felgueiras.
Ask a questionChoose names for your vegetable rows or herbs, then adapt a shared marker design in your free Easel account. No credit card is required.
