Make a four-in-a-row game
Arrange a four-in-a-row game in Easel, sizing its playing grid and counters together for a falling-disc board or a three-dimensional peg game.
See the finished builds
Design your own four-in-a-row game
The animation below shows drawing a three-dimensional four-in-a-row game from scratch in Easel. A wooden base seats sixteen separate dowels, and two colors of wooden counters slide onto them. Players take turns adding a counter and try to make a line of four horizontally, vertically or diagonally. Assume 5 mm dowels 60 mm long, 25 mm counters cut from 10 mm stock, and a 22 mm finger-access envelope between neighboring counters; these are untested design references. Draw a 200 × 200 mm base in 10 mm wood. Place sixteen 5.2 mm blind seats, 8 mm deep, on a four-by-four grid with 50 mm centers. Draw a 25 mm counter with a centered 5.5 mm through-hole; cut 64 counters and finish 32 in each color. The 52 mm of dowel above the base holds four 10 mm counters with 12 mm remaining above the stack. Adjacent counter rims are 25 mm apart, giving the 22 mm finger reference 3 mm of additional room. The seats retain a 2 mm floor and give the dowels 0.2 mm total clearance; use wood glue to secure them after a scrap fit test. Remove profile tabs, smooth the counter holes and confirm comfortable placement and removal before finishing the set.
Recorded in the Easel editor, playing at 4× real speed.
Drop discs into channels or stack them on dowels
For a falling-disc board, match the disc thickness to the space between its plywood faces. For a case-stored peg game, counter thickness also determines how long the storage grooves must be.
Bob Clagett’s completed upright four-in-a-row game with colored discs and original video-title branding Connect Four gameby Bob Clagett
Connect Four game
Bob’s upright game uses two birch-plywood faces, each with 42 viewing holes, around separate acrylic discs. Cut his shared face layout twice; add the wooden channel separators and bottom stop, CA glue, acrylic discs and an oak storage box made separately. Epoxy matching magnets into the box halves and board sides so the box closes for storage and snaps onto the board as its playing stand.
Cristiana Felgueiras’s wooden three-dimensional four-in-a-row game with dowels, counters and an open case 3D Connect Fourby Cristiana Felgueiras
3D Connect Four
Cristiana’s three-dimensional game stacks wooden counters on a four-by-four grid of separate dowels. Her seven workpieces cover the main board, lid, groove operations, customization, counters, sides and optional magnet caps; add the dowels, case magnets and adhesive to assemble the wooden case and its magnetic closure. Fit the dowels into the board seats and counters over their stems. Her native notes call for 32 counters of each color in 10 mm stock: thicker counters require adjusting the board and storage-groove length. Run the groove layout on both board and lid with the specified bull-nose cutter.
See more connect four search results →
Make the channel strips thicker than the discs
Log in to post a question in the project discussion; replies are not guaranteed.
Bob Clagett’s board instructions call for nine wood strips slightly thicker than the acrylic discs: one the length of the board and the others its height.
Project notes by Bob Clagett: read the source.
From Connect Four game by Bob Clagett.
