Small projects for the table
Make your own CNC coasters.
Start with a finished set, then choose a flat inlay, a recessed rim or a stack that stores neatly.
Explore the finished projects
Design your own coaster
Draw a round coaster in Easel, add a ring groove, a shallow recess and the letter M, then preview it in 3D.
Recorded in the Easel editor, playing at 8× real speed.
Made by Easel gallery makers
Stack a set, fit an inlay, or add an opener
Compare finished builds with different surfaces, materials and storage. Each project links to the maker’s page and the actual Easel design. The coffee set and monogram examples include V-carving stages, which require Easel Pro.
See more coaster search results →
From the makers’ comments and project notes
Details to use in your own coasters build
Lift dried glue with a sharp chisel before sanding
John McWhirter recommends a sharp chisel for the first pass over dried glue around an inlay: it cuts the glue rather than smearing it across the wood. Brian Adle adds that wet glue is easier to wipe away, but partly dried, gummy glue is better left to dry before using the chisel. The cleanup method depends on when you catch the squeeze-out.
Comment by John McWhirter: read the source.
From Simple Inlay Coaster by Thomas L..
Make a coaster set of your own
Create a free Easel account, copy a community design and adapt it to your material and hardware.
