Wood clocks for walls, shelves, and mantels
Make a wooden clock
Start from scratch or customize a finished clock another Easel maker designed. Creating an Easel account is free. No credit card required.
See the real projects
30 projects in the Clocks collection
3,745 copies of collection projects
36 comments on collection projects
Start from a real build
Choose the clock before you choose the cut
A clock project has two dimensions to get right: the face you want to see and the movement that has to fit behind it. Decide whether your piece will hang on a wall or sit on a shelf, then choose the movement, hand length, face thickness, and overall size before you resize the design.
The Easel previews let you inspect each stock size and toolpath before making a copy. Treat the listed dimensions as a starting point, not a substitute for measuring your own blank. The gear-clock project has no build instructions, and the other makers’ probe or setup choices may be specific to their machines, so verify your own work zero, bit, and movement fit rather than copying a number blindly.
Real clocks from the Easel gallery
Three ways to make a wooden clock
These carved projects include a layered day-and-night scene, a large V-carved face, and an exposed gear design. Some rely on Easel Pro features such as V-carving or Pro designs, so check the project details and your plan before building from a copy.
See more CNC clock projects →
Before you cut
Plan the movement, material, and finish
Pick the clock movement first
Choose the movement and hands before sizing the face. Check the shaft length against the finished stock and any layers, then use the movement maker's dimensions for the center hole and clearance.
Fit the design to your machine and stock
Measure the actual board and compare it with the preview's workpiece size. Leave room for clamps outside the cut paths, check the deepest toolpath against the bit's cutting length, and preview any tiled setup before starting a large face.
Treat each bit and profile as a separate job
A V-carved numeral, a pocket for a gear, and an outside profile need different checks. Confirm the selected bit and depth for every operation, dry-fit gears before assembly, and keep the workpiece held securely through the last cut.
Test color and finish on matching scrap
If you plan to seal, paint, stain, or clear-coat the face, test that sequence on offcuts from the same board. Let paint cure before sanding and make sure finish does not bind the moving parts.
Make a clock that fits your space
Create a free Easel account, no credit card required. Inspect a clock project, then adapt a copy for your CNC. V-carving and Pro designs require Easel Pro if your chosen clock uses them.
