Make Christmas decorations
Design wooden Christmas ornaments in Easel with cutout shapes and a hole for hanging.
See the finished builds
Design your own Christmas ornament
The animation below shows drawing a round Christmas ornament from scratch in Easel. It uses thin birch plywood, as in Richmond Cox’s angel ornaments, and a separate thread loop passes through a small hole near the top.
Recorded in the Easel editor, shown at 3× speed.
First draw a 3-inch circle on the blank workpiece and choose an outside cut through the example ⅛-inch stock.
Add a 3/16-inch through hole on the centerline near the top, leaving wood above it to carry the hanging loop. The recording places its center 0.456 inches below the outer top edge.
Cut and smooth the disc, then add paint or a name and thread the loop through the hole. This recording makes a plain ornament blank, not the angel artwork or assembled drum. Its dimensions are design assumptions, not a tested carve.
Hang an angel, build a drum or arrange a mantel village
Flat cutouts and stacked pieces make different decorations. Thread, glue, paint and hanging hardware are separate supplies; the shared Easel files provide the wooden shapes.
See more christmas search results →
From the makers’ notes and instructions
Seal fine plywood before cutting
Read the public project discussion; log in to add a comment.
Keep the angel’s thin details together
In Christmas Angel’s, Richmond Cox says to apply sanding sealer before cutting to keep the fibres tight. His instructions pair that preparation with 3 mm birch plywood and a 1 mm cutter.
Project notes by Richmond Cox: read the source.
From Christmas Angel's by Richmond Cox.
Leave room for the hanging loop
Keep the hole inside an unbroken border of wood, with space below it for the decoration you want to add.
