Centerline Marking Toolby Paul J. BennettA plywood guide with replaceable pins
Paul’s plywood tool uses a rounded body with a pencil through the middle. The shared Easel file contains the body and three holes, but its original outline is shallow: Paul finishes releasing the body with a band saw. Adjust hole depths for your sheet. The pins and pencil are separate parts, not pieces supplied by the CNC file.
