Make a candle holder for your table
Carve a heart, group small tealights or fit wooden pieces together around a candle. Explore finished community builds and open a shared Easel design to make one like it.
Explore the candle holders
Design your own candle holder
Watch three tealight pockets and two small carved stars take shape in a soft maple candle holder in Easel, then see the design turn in the 3D preview.
Recorded in the Easel editor, playing at 7× real speed.
Cluster tealights, carve a heart or build an interlocking base
Choose a design for one candle, a centerpiece or a battery-lit decoration. Each maker’s project shows the finished object and links the shared design.
A rectangular wooden holder with honeycomb carving and three orange candles on a windowsill Tri Hex Votiveby Eric Pavey
Tri Hex Votive
Decorate a long wooden holder with hexagons around three candle pockets. Eric’s photographed build uses scrap redwood; he recommends harder wood to keep the fine details crisp. The shared file has separate stages for the V-bit borders, smaller honeycomb detail and endmill pockets. Allow enough stock around the detail pattern, and trim the board ends separately as his instructions describe. His safety note says to use self-contained metal-tin votives, not the bare candles in the photo.
See more candle projects →
From the makers’ comments and project notes
Details to use in your own candle holders build
Use separate cutters for the ring and its large opening
Rafi Bernstein describes cutting the outside with a one-eighth-inch bit and clearing the candle opening with a larger bit. Fred Housel replies that he recommends separating those operations, while keeping the shared beginner version simple. The larger opening does not need to be cleared with the same small cutter used around the ring.
Comment by Rafi Bernstein: read the source.
From Honeycomb Tealight Candle Holders by Fred Housel.
Start your candle holder
Create a free Easel account to copy a shared design and adjust it for your table. No credit card required.
