4U Fly Rack Sleeve for a Peli Caseby Jamie Mckivitt4U Fly Rack Sleeve for a Peli Case
Jamie’s 400 mm-deep fly-rack sleeve uses 9 mm Hexa plywood and separate Penn Elcom R0863/2MM-04 rails. Select the matching 9 mm side, top and bottom layouts from the six workpieces, then add rail hardware, cage nuts, equipment screws and transport-case foam as needed.
